跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 个问题 查看全部
Fuse F2 (for Battery) is blown, need specs for new fuse
I tested the fuses as I got told that its the fuse tjats blown in the nintendo, she was right, it is the fuse (at least). Now my problem is, the two fuses in the nintendo are like 2mm2 smd parts that are only labelled with “32”. From the form I would say its a resistor, but with 32Ohms? Also, F1 measures under 0.1Ohm so cant really be. There are replacement fuses out in the web, but 3 pieces should cost 7€ plus shipping for 3 smd fuses just cut from a tape. Sadly no seller posted infos like mA ratings or whatever.
Does anyone of you know what values these fuses have? As the battery is a 3.7V Li-Ion, it would be enough to know the current Rating
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Researching online the consensus seems to be that it is a 0603 0.5A fast acting fuse.
The mouser part number is F0603E0R50FSTR but no doubt there are other suppliers as well.
The “32” on the fuse is the voltage rating and in this case is not that important, as it is equal to or more than the supply voltage. It is the current rating that matters as you said. Most fast acting smd fuses are rated at either 24V, 32V or 63V.
Here’s a link that gives the smd dimensions. Scroll down to the Passive rectangular components section, so that you can verify that the package size of 0603 is correct.
这个答案有帮助吗?
得分 3
1条评论:
Thank you very much :D
完成的
添加一条评论
添加你的答案
PyroRider 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 27
过去 30 天: 117
总计 2,975
