Fuse F2 (for Battery) is blown, need specs for new fuse
I tested the fuses as I got told that its the fuse tjats blown in the nintendo, she was right, it is the fuse (at least). Now my problem is, the two fuses in the nintendo are like 2mm2 smd parts that are only labelled with “32”. From the form I would say its a resistor, but with 32Ohms? Also, F1 measures under 0.1Ohm so cant really be. There are replacement fuses out in the web, but 3 pieces should cost 7€ plus shipping for 3 smd fuses just cut from a tape. Sadly no seller posted infos like mA ratings or whatever.
Does anyone of you know what values these fuses have? As the battery is a 3.7V Li-Ion, it would be enough to know the current Rating
