跳转到主内容
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 个问题 查看全部
Is there any way to change or repair the ribbon cable?
My screen has white vertical lines and is lacking of colour intensity everywhere. I already did the self diagnostic test, restarted it, reinstalled the os. I really think there is a problem with the flex cable. On ti 83 calculators it was possible to solder cables to replace the ribbon cable, is it possible on ti 84 plus ce?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What about for ti83?
完成的
添加一条评论
2个答案
最有帮助的答案
Thanks for doing all those troubleshooting steps, that really helps me out!
Unfortunately, you can’t repair the ribbon cable the same way as the TI-83 family since the CE’s ribbon cable is significantly smaller (you can see it circled in the teardown). The community has been unable to find a compatible LCD you can buy separately, so the only way to get a new LCD is to buy a donor calculator. Fortunately, every TI-84 Plus CE (or TI-83 Premium CE) display is compatible with each other. Just be warned that it is not compatible with the TI-84 Plus CSE’s LCD.
这个答案有帮助吗?
得分 2
添加一条评论
The ribbon cable is attached via a connector that has very tiny solder points. You could try just getting a new screen from another calculator with a different issue, since getting a replacement screen is almost impossible.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
domsflyon 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 15
过去 30 天: 28
总计 838
