跳转到主内容
加入维修社区 - 创建账户
Kenwood Receiver 型号 KR-V7070 是一款由 Kenwood Corporation 生产的影音接收机。Kenwood 是一家日本公司,致力于设计、开发和营销车载音响系统、高保真家庭及个人音响系统、专业双向无线电通讯设备以及业余无线电(“火腿”无线电)设备。
Lower speaker volume output
The volume output on my speakers isn't anywhere as loud as it used to be. Before the volume you could get at say level 60 you need to turn up to level 30 (backwards, I know). All connections are good. Nothing has changed. Not sure if amplifier is going bad.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Sometimes when a knob goes bad, it's the knob's potentiometer. What's a potentiometer? It's basically a resistor that can change resistance depending on how far you turn it. Usually there's a metal contact that slides against another metal contact, and often these contacts can wear out or get dirty. If it looks like the potentiometer contacts are reachable, I would try cleaning it (obviously with the power disconnected). If not, you may see if you can find a potentiometer with the same resistance ratings and try replacing it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Craig Buike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 3,349
