跳转到主内容
加入维修社区 - 创建账户
三星 RB217AC** 冰箱的维修和信息指南。这是一款底部冷冻室型号,不带冰块分配器,冷藏室配备抽屉和柜门,并采用自动除霜和防凝露加热器开关。本页面涵盖了符合 RB217AC** 型号代码的所有相关信息。
Ice tray not completely filling
Hi
i have a Samsung RS21 fridge freezer
the ice maker seems to be functioning but is only partially filling with water. Enough to fill just 2-4 squares.
I’ve checked the water pressure into the fridge and that seems good and the water comes out at a good oressure
it just seems as though the water to the ice maker cuts off too soon.
it is a second hand FF so not sure how long it’s been like it
many thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here’s a section from the service manual that shows the value settings for the ice maker’s different fill times and temperature sensor options.
I think that to access the settings you have to press Power Cool and Freezer Temp simultaneously. Hopefully then there are prompts as to what to select as the manual isn’t that specific
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
1条评论:
Worked a treat, thanks so much.
由完成的
添加一条评论
添加你的答案
Ryan M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 1,699
