cluch don't work at all but dosen't slip
clutch has no prusure in pedle
Check your clutch master cylinder for fluid. If you have no pressure on your pedal, I would think that you a. have no fluid in your cylinder or b. a leak in your line c. a master cylinder that has a broken seal, or d. a leaking slave cylinder.. To check it of course check the fluid first, if low, refill. Than bleed the line, and check for leaks. If you do not see any leaks and if your fluid is sufficient, you have a leaking cylinder....you can download the clutch repair from the service manual from here Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 482
2条评论
new master cylinder new slave cylinder
由 michael sliney 完成的
Check the manual and see what you can find. It does sound like a loss of pressure. did you check for leaks?
由 oldturkey03 完成的
