第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3260 个问题 查看全部
iPhone 4 won't charge and reboots constantly.
From beginning.. I was given a water damaged iphone 4 from a friend. It took a spin in the washing machine..
But!
The telephone works perfectly for about 5 minutes before it just reboots and does it constantly, and the battery refuses to charge, but it's feeling the wall loader and give the sign of "loading" but nothing happens. I've ordered a new battery so it will probably charge then. But that is not what im worried about..
The thing is, everything works for this short while, internet, calling, texting and so on. But then it just reboots, beforce it reboots I lose my coverage and then maybe 2 minutes later it reboots.
My solutions step which been made:
1) Ordered a new battery
2) Just had it to try in parts for about 1,5 day.
3) Reset phone through Itunes.
Im worried the battery change ain't going to affect the rebooting problem? What could be the solution to the rebooting problem? Can it be fixed by just changing the battery? The warranty is out, so im trying to solve it as cheap as possible.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
Robert, I think you are doing all the right things. You can double check on the water damage and make sure that you have no corrosion, and/or debris on the logic board. I think your culprit here is the battery. Use this guide Electronics Water Damage to help you with the water damage and once you have your new battery, reevaluate. I bet it's going to work ....:-) let us know, good luck.
这个答案有帮助吗?
按维修分数 2
添加一条评论
Just like oldturkey said ^ , you seem to be right on track. His link should help you out, and if you are still looking for more info, here's a nice guide Pollytintop made to assess damage.
这个答案有帮助吗?
按维修分数 1
添加一条评论
Guys, it's actually working! Never reboots and looks like new! Just want to post a video for people who come over this thread with the same issue, found a few youtubeclip which has the exact similar problem but mine was water damaged:
http://www.youtube.com/watch?v=km61mY9ID...
Fixed with just a new battery!!! God im glad! :) Thanks everyone!
(Had for some reason do a new account)
这个答案有帮助吗?
按维修分数 0
添加一条评论
I bought a iPhone 4s from a friend yesterday. It takes a long time to charge, and when it charges up to 5 percent it turns on , shows the apple logo then it shows a nothing but black on the screen then about 1 min later it restarts itself . Is it the battery? What might be the problem ? Please help me .
I think its the battery but I'm not sure .
Any solutions?
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Robert 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 7,268
