跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad X1 Yoga 2nd Generation 是一款 14 英寸笔记本电脑,于 2017 年春季发布,可通过型号 TP00076C 进行识别。
USB C ports non functioning at all.
Is there any way to replace these parts so i can charge it again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi
Have you checked the status of the USB-C ports in Device Manager, you didn't say?
完成的
its dead atm cause i cant charge so i cant check, its a gen 5, for some reason this option is not avalible , any replacement parts?
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
You may be out of luck as far as easy replacements are concerned as the two USB-C port are hard mounted on the motherboard.
Are the ports physically damaged at all?
If not then it may still be a software problem and it may be easier to temporarily replace the battery with a fully charged compatible replacement battery and check the status of the USB-C ports rather than removing the motherboard and to replace the USB-C ports as they may not be faulty.
Here’s the hardware maintenance manual that may help with either option that you decide to go with.
这个答案有帮助吗?
得分 1
添加一条评论
I had one c drive fail. It was covered under warranty. They replaced the motherboard. Apparently not uncommon problem. I WATCHED part of a one and half hour video as someone repaired the port with welding equip or something. It was not an option for me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yahir Nava 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 881
