跳转到主内容
加入维修社区 - 创建账户
型号 A1347。发布于 2011 年 7 月 21 日。配备 Core i5 或 Core i7 处理器。带有 Thunderbolt 接口。该设备也常用于 Mac mini Server 配置。
Not starting and Logic board debug
My a1347 Mac Mini has been turned off for a few years and now it will not start. When I press the power button the fan goes on for a second, the light goes on for about a second too and it makes some sort of sound. The sound is not the fan as I also hear it with the fan disconnected and I have some distant memory of that the sound always there on start.
I have checked that the power supply gives 11.8V on all 4 pairs as of this guide so it appears to not be the problem. Complete Dead - How To Check Power Supply Vs Logic Board
So now I am rightly of wrongly looking at the logic board. I have read in a few other forums of failing capacitors near the power supply on Macs. Can someone point out where in the photos these might be? Other ideas of where/what to check and how are also appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论:
Did you replace the NVRAM coin battery?
完成的
No but I measured it to be under 3V. Is that enough voltage?
完成的
If the system had been sitting unplugged it will need replacing. I would start there.
完成的
I changed the old battery (2.9V measured) to a new one (3.3V measured) but it didn't help. Still the same when starting the Mac Mini. Any other ideas?
完成的
So can anyone point where the capacitors are on the logic board that are related to the power supply?
完成的
显示更多的1条评论
添加一条评论
1个答案
Sadly, as far as I know Apple never offered schematics and board views for the Mac Mini systems. So trying to nail down what is bad gets tricky! You’ll need to carefully inspect the logic board for burnt parts, staining or corrosion damage. I would give it a good clean as sometimes dust hides things.
Otherwise, it’s time for a new logic board.
这个答案有帮助吗?
得分 0
2条评论:
Still, I can’t get this to start, for reference I have tried this
Measured the power supply both on the connector and the exposed pins on the board, 11.8V
Changed the 2032 coin battery
Cleaned the board with electronics cleaner
Tried the CMD-Alt-P-R combination many times.
Now I am considering a used logic board if I can find it for a reasonable price.
完成的
Also no obvious burns or corrosion on the board
完成的
添加一条评论
添加你的答案
Alpaca 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 27
总计 486
