跳转到主内容
加入维修社区 - 创建账户
型号 SFQ-08。蓝牙调频闹钟无线音箱
missing antenna need diy help
Have a Soundfreaq Sound Rise Bluetooth speakers/FM alarm clock and lost the FM antenna. I can’t find a barrel plug that will fit in the female part of the radio and also don’t know how to DIY an FM antenna (material, length).
Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Greetings, Clueless…
I have the same predicament. I’m not 100% certain but I think the barrel plug needed should be a size 4.5*3.0mm. These usually have a blue plastic tip at the end of the plug.
I tried the various barrel tips I had laying around but none fit…all had either too wide of outside diameter or too small of inside diameter for the Soundfreaq antenna jack.
There are many inexpensive kits available on Amazon, eBay, etc. if you want to pick up some to test.
Any copper wire will work as an antenna, possibly even without a plug attached.
You can also email Soundfreaq support at Soundfreaq.com to ask if they have a replacement antenna.
Good luck!
这个答案有帮助吗?
得分 1
1条评论:
Cullmudgeon--
Thank you for the reply!
I too have tried different sized barrel tips but unlike Goldilocks, none were "just right". I think the barrel diameter is perfect, need to track one down.
I emailed Soundfreaq support and have not heard a reply.
It would be nice to be able to listen to FM. However the speaker does stream music nicely via bluetooth.
Thank you again!
由完成的
添加一条评论
添加你的答案
Clueless 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 24
总计 1,021
