跳转到主内容
加入维修社区 - 创建账户
苹果为桌上型或笔记本 Mac 电脑设计的操作系统。
Office 2011 not opening.
Hi, I was wondering if you could help, everytime i open Word, Powerpoint, or excel for mac (the rest work fine), It comes up with "The Office for mac installation did not complete successfully because there was a problem with the installer"
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The problem is solved, I downloaded a fresh copy of office
这个答案有帮助吗?
得分 0
添加一条评论
The older versions of Office installer have a certificate within them to make sure they are not tampered with. This certificate has an expiration date which on the 2011 version has expired. I would recommend you get a newer version that works on your given OS-X/macOS or you’ll need to alter your systems date back to 2012/13 so the installer thinks its back within the certificates window.
I would also make sure you are running the highest version of OS-X/macOS your system supports as well to be safe.
For reference: If you've got an old macOS install image, it will probably stop working today
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
macbookiphone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 454
