跳转到主内容
加入维修社区 - 创建账户
Ryobi P320 无线射钉枪 (2016) 是一款专为木工和建筑任务设计的通用工具,具备无线操作功能,并兼容 Ryobi 的 One+ 系统,使用范围更广。凭借深度调节和 Airstrike 技术等功能,它为各种应用提供了便捷可靠的性能,其故障排除和维护方法确保了工具的持久耐用性。
How is this part not available?
My nailer took a tumble down the stairs and broke the metal bracket that the “no mar contact tip” attaches to (part of the depth set mechanism and the piece that sticks the furthest away from the body of the tool.) I've searched all the parts websites and it seems every o-ring and screw and other part is available, but I cant find this one and can't even find a good name for it. Not willing to buy a new tool over a $5 part. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I also have the same problem, the tip broke off. Can I buy the assembly which includes this part?
Steve
claretsfan@gmail.com
完成的
添加一条评论
4个答案
最有帮助的答案
Do you see the part on this diagram?
If so, this site should help identify it and may offer it for sale
It appears that that is part of the magazine assembly.
https://www.ereplacementparts.com/ryobi-...
这个答案有帮助吗?
得分 2
6条评论:
Thanks Issac, but no, it's not a numbered part on that diagram /website. It’s the metal piece that screw 36 goes into after piece 35.
完成的
@anonnimity Updated answer. Looks like it's part of an assembly, not sold as separate.
完成的
Ryobi OEM 79007001084 Nailer Driver Assembly R213BNA R150FSA R213BNE
完成的
It's called a "Work Contact Element" but part #79007001084 for the P320 does not fit on the assembly. Part 1084 has the same holes and fits on but it's a solid piece of metal. The one that broke on mine (Same as above) has metal grooves down the body and the width of the contact element isn't wide enough to slide over the nail tray. I've not found a replacement part the same as what broke.
完成的
The piece you are looking for is not marked and I'm having the same issue! it goes through 35 and is the piece that you attach the no mar pad to! Drop your tool and it breaks off. At this point I'm so disappointed that I am now in the process of replacing my Ryobi tools! Never by Ryobi they are junk!
完成的
显示更多的1条评论
添加一条评论
这个答案有帮助吗?
得分 2
添加一条评论
It sounds like the specific part you're referring to is the metal bracket that houses the "no mar contact tip" and is integral to the depth set mechanism of your Ryobi Cordless Brad Nailer P320 (2016). Unfortunately, without a specific part number or a clear description, finding this part can be challenging.
One suggestion is to reach out directly to Ryobi customer support. They may be able to provide assistance in identifying the part and possibly ordering a replacement for you.
这个答案有帮助吗?
得分 1
添加一条评论
Mine was Part 42 here: https://ryobipower.ordertree.com/model?m...
这个答案有帮助吗?
得分 0
1条评论:
sorry, was for trhe P321...
完成的
添加一条评论
添加你的答案
anonnimity 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 47
总计 2,500
