跳转到主内容
捷威笔记本电脑制造高质量的笔记本电脑和上网本。 由宏碁集团拥有。
220 个问题 查看全部
Error 0xc000035a vista recovery is not working...
So my client has a Gateway Vista laptop MA7 with a 0xc000035a error, failing to boot, saying something about winload.exe.
It says to do a Vista recovery repair, which I thought would be easy, but the repair CD that I downloaded says its not compatible with this version of windows. It's 32bit for sure, but I'm not sure what version of windows vista he has.
Can anyone help?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Looks like it is/was a 64 bit version, or a botched install thereof. I guess other than formatting and reinstalling the proper version, not much to recover. you could try and see if the D: (or other partition) is still on the HDD. Gateway places their recovery on that partition. On startup,Press F11 after the POST display is complete. More info about it on here. If not, you could try to download Ultimate Boot CD,( it used to be free) and give it a try.
The UBCD website is a PITA due to lots of banners and redirects, you can get it as an ISO via a torrent from here Of course you will still have to burn the ISO to a CD etc....but nothing to lose but your client Good Luck
这个答案有帮助吗?
得分 3
1条评论:
Cool thanks!
Just wanted to say that part of the boot error was something like "Trying to run a 64 bit program, but the CPU is not capable of doing so"
I'll try that when I get home.
Thanks!
完成的
添加一条评论
添加你的答案
Mason Curry 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 4,526
