跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
LCD Panel replacement because of intermittent backlight
Same story that's probably been told 500 times, my backlight intermittently works. The screen looks fine when using a flashlight, and plugging in an external monitor works perfectly fine. The backlight will come on if you repeatedly toggle the brightness buttons on the lowest setting and will stay on for 10-40 seconds unless you bring the brightness up real high, in which case it goes out immediately.
I've replaced the inverter, and I've replaced the inverter cable. Same results.
So it seems like I have three options, from cheapest to most expensive:
1. Replace CCFL
2. Replace backlight assy (I assume he means assembly? recommended here)
3. Replace the LCD Panel
Seems like replacing the CCFL is incredibly complex so I won't bark up that tree.
So I'm left with either buying a cracked panel on ebay to try and extract and replace the assy, or just purchasing an entire new LCD panel.
So my questions are:
#1 - Given my symptoms and what I've done so far, could I be confident an assy replacement or panel replacement would fix my issue (if it's not the inverter or inverter cable, it seems like the only other possible thing would be the logic board. But an external monitor working fine should negate that, right?)
#2 - If I go the route of buying a cracked screen and replacing the assy, how difficult/obvious is that?
#3 - If I go the route of replacing the LCD panel, does it matter which kind? My research shows there are four kinds of displays. I have a LTN133W1. iFixit doesn't mention which one they sell. Am I OK buying any of the four, or do I need to replace mine exactly?
Thanks for your help!
Replace an LCD Panel compatible with the 13.3" MacBook laptop. 1280 x 800 pixel Resolution.图片
产品
MacBook 13.3" LCD Panel
$49.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Replace the LCD with EXACTLY the same model.
这个答案有帮助吗?
得分 3
2条评论:
Did this and now it's working great. Thanks for the advice.
完成的
Some times the answer is short and simple ;-) Glad I could help.
完成的
添加一条评论
Hello!
That's LCD will work in Macbook Black? The model is MB404LL/A.
Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vgp916 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,418
