跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
iPhone got wet and now screen is very dim.
My iphone got wet in a washing machine and than it was working properly. but suddenly its screen become very dim. I can see only under bright light.
can anyone help me to fix this problem
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I am not sure about replacing the display or the logic board, that's like using the big guns right away. If you are handy, try to replace the coil on the logic board first. A lot cheaper...you can get the 6R8 coil on eBay and many other places or from here and if you are wondering how to do it, you can watch a video.
这个答案有帮助吗?
得分 2
添加一条评论
Have you thoroughly dried out your iPhone? If not, then you may want to use the Thirsty Bag to get all the moisture out of your iPhone.
If you still have the same problem after drying, then you probably need to replace the display or the logic board.
iPhone 3GS Display图片
产品
iPhone 3GS Display
$19.99
这个答案有帮助吗?
得分 0
添加一条评论
Old Turkey is spot on here.
First call would be the 6r8 coil.
If still dim then I would replace the screen but more than likely it will be the 6r8.
Dont replace the logic board until all esle has failed.
Its expensive and usually un-necessary!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bobby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 8,873
