跳转到主内容
加入维修社区 - 创建账户
门窗的维修与拆解指南。
How to adjust uPVC window door?
I moved to this new flat, and there seem to be an air leak from the balcony window, the leak only goes from the side where the hinges are! is there anyway to tighten the door so it could be sealed, i must mention that the rubber seals are brand new and the main issue here is that the window is not adjusted right, only problem is how to make that adjustment?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
How to slowly window 2 side lock problems?
完成的
添加一条评论
1个答案
最有帮助的答案
hi @sureno ,
This link may be of some help.
这个答案有帮助吗?
得分 1
6条评论:
the door seems to have a butt hinge type, now I am not sure if I am able to adjust the compression from the hinge's side, but if I do adjust the one from the lock side will that tighten the seal for all sides of the window? or will it only compresses it from the lock side alone!?
完成的
@sureno
It may be a case of trial an error to see if you can get it right as there isn't too much adjustment in a butt hinge.
Here's another link that may help a bit more
完成的
Alright, appreciate the input. I will do try that, I am trying to get the theory right first, in order not to screw anything up as the windows are newly installed :). thanks a lot for your help @jayeff !
完成的
I will definitely try your link. I will let you know if this one work. Thank you!
完成的
@sureno
if they were newly installed by a professional company and not by you, call them back to fix it as it wasn't done correctly if there is a gap that allows a draft through
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Sureño 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 479
