跳转到主内容
加入维修社区 - 创建账户
型号 A1347。发布于 2011 年 7 月 21 日。配备 Core i5 或 Core i7 处理器。带有 Thunderbolt 接口。该设备也常用于 Mac mini Server 配置。
Issues with ram upgrade
This is the Mac mini Server 2011 i7 Model.
So I bought this kit.
https://www.amazon.com/gp/product/B00SNM...
The issue is the following. When I put a 8GB module on the bottom slot. I get the 3 beeps 5 seconds pause error. When I put it on the top module it works.
So now I have the original 2 GB stick on the bottom slot and a 8GB module on the top slot. The computer is working and it says it has 10GB of Ram.
Nonetheless I don’t understand why the bottom slot doesn’t work with the 8GB module?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
RAM slots in almost all computers has a certain arrangement in which they need to be populated. In standard ATX-like motherboards with 4 slots you put a single stick in the 2nd from the left slot, two sticks go in the 2nd and 4th slot and four sticks fully populate the slots. In the mac mini, they way you describe it, a single DIMM should populate the top slot and two DIMMs populate both slots. It’s just a wiring thing in the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pigoath 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 361
