跳转到主内容
加入维修社区 - 创建账户
Xbox One Model 1698 无线控制器由微软于 2015 年与 Model 1697 控制器一同发布。此款控制器类似于 Model 1697,但在内部进行了修改。 它比普通控制器具有更多功能,例如可拆卸的拇指摇杆和金属十字键。该控制器主要专为游戏主机使用而设计,但也兼容 PC。
Why does the right trigger activate without touching it
My brothers controller recently started to get the right trigger problem where it would constantly activate but the left trigger wouldn’t work is there anything that my brother and I can fix this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
My RT and LT buttons press themselves and RB is acting like the start button. Also my right stick isn't doing anything. The ABXY buttons work perfectly fine though.
由完成的
添加一条评论
1个答案
I've had controllers do this before. A sign that it's taking to much physical wear. Usually, a controller will do that when its hardware is resting on the internal components. Or the “middle man” component isnt doing its job because it is broken/worn or out of place. The only way to know would be to take it apart. Look for an internal part that gives the trigger resistance so it isnt ever resting on the internal button after you have applied pressure. Then see if it's the trigger itself by taking off the front controller plate and seeing if the button makes contact with the necessary button. If so, check the internal buttons to see if they are stuck or in a bind. Press them a few times and see if the console receives signal. Make sure everything is secure and safely reassembled.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Urquizo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 49
总计 3,580
