跳转到主内容
A film and slide scanner from Nikon identifiable by the model number LS-40 ED.
5 个问题 查看全部
Anyone know how to open this up for cleaning?
I have a Coolscan IV slide/negative scanner and would like to clean it. There is gobs of dust on the element. Can't really just get in there with an air can.
There are screws holding the steel shrouding on the back, but I cannot seem to get the plastic front plate off. Not sure if it should pop off, or if there are other connectors.
I would appreciate help here.
Many thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If you check on the link I sent you, it says "To get the front faceplate off, use a flat screwdriver to gently pry the tab away from the chassis"
完成的
添加一条评论
1个答案
已选择的解决方案
jmmx, check on here it should show you how to do it....Good Luck
这个答案有帮助吗?
得分 2
2条评论:
This is great. I guess I will give it a try. I received a quote of $40-90. I am sure it would wind up closer to the high end.
Many thanks!
完成的
Wow that seems steep. Looks like you could do most of it by yourself. Just take your time and keep it clean ;-) Save some money....
完成的
添加一条评论
添加你的答案
jmmx 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 1,945
