跳转到主内容
加入维修社区 - 创建账户
Asus Zen AiO Pro Z240IC 是一款一体式台式计算机,以其 4K 超高清屏幕和 1 TB 硬盘而闻名。
Is the CPU replaceable?
Thinking to change it from i7-6700T to i7-7700T
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
It might be as the chipset on the motherboard is an Intel H170 which supports an i7 7700T
The big problem is whether the original CPU is hard mounted on the motherboard or not and can be removed.
Here’s the ifixit Asus Zen AiO Pro Z240IC 主板更换 guide. Unfortunately the image in Step.14 doesn’t show whether it is or not as the heatsink is still in position
Update (01/03/2021)
Hi,
Looks like I didn’t scroll down far enough ;-) and also it looks like you’re right when looking at a close up image of the CPU
(click on image to enlarge for better viewing)
Just wondering if it would be worth it though looking at this
The real world speed test of 74.2% vs 72.4% is only a 1.8% difference, so will it be even noticeable?
这个答案有帮助吗?
得分 1
1条评论:
I've found it from Asus Zen AiO Pro Z240IC Heat Sink Replacement, under Step 16.
It seems like the CPU is replaceable.
由完成的
添加一条评论
添加你的答案
du choon kok 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 27
总计 1,256
