跳转到主内容
加入维修社区 - 创建账户
Google Pixelbook Go 是一款来自 Google 的高端 Chromebook,采用耐用的镁合金翻盖式设计,外观简约。于 2019 年发布。型号:GA00521-US。
Re-insert clamshell pin into hinge
One end of the hinge on the Google Pixelbook Go has slipped out of place. I do not know how to reinsert it. The two pieces of the clamshell do not feel flexible enough to bend and allow the pin to slip back into the hinge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
Curious what you ended up doing here. Your issue (and mine) is that the hinge itself is broken. This is caused my the screws loosening causing a torsional flex in the hinge when then snaps it.
The screws loosen over time due to hinges being too tight.
Google isn’t supporting the devices and there’s no way to get replacement parts.
这个答案有帮助吗?
得分 0
2条评论:
TL;DR Don't buy Pixelbooks.
I returned the broken Pixelbook to the seller and got back 80% of the purchase price. The money I got back was enough to buy two Lenovo Chromebooks w/ 8GB and touch screens.
由完成的 分享
I have the same Pixelbook AND the exact same issue. I have another problem as well, when the right hinge is lowered, the display goes black, everything still works, the device isn't turned off, I believe it might be a severed display cable
由完成的 分享
添加一条评论
It seems that the hinge is snapped from the image. Could have happened when the LCD is accidentally pushed exceeding the limit. Can be fixed by removing the back cover and swap out the damaged hinge.
这个答案有帮助吗?
得分 0
添加一条评论
I was able to buy a hinge on eBay (at outrageous price for such a small element) and replace it, otherwise you can replace the whole unit for $$$.
这个答案有帮助吗?
得分 0
添加一条评论
@piotrkaminsk163 How did you replace it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aaron Hoffer 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 27
总计 1,640
