跳转到主内容
加入维修社区 - 创建账户
Fujifilm X100T 是 Fujifilm Corporation 于 2014 年末发布的 X100 系列第三代相机。它有黑色和银色两种配色,机身正面印有大写的“T”字母,借此可识别该机型。它具备 Wi-Fi 功能,可拍摄 1600 万像素的照片。
X100 F bottom plate replacement
Hi!
I have to replace the bottom plate od my x100F. I have watched X100T dissesembly guide on this site. It is not clear do I have to peel the leatherette or do I just remove the six screws at the bottom of the camera with the leatherette on. Did anyone took appart the x100F?
Thank you
Neven
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
I took both cameras apart and removing the bottom plate of the X100F is way easier than with the X100T. You just need to remove 5 screws in the bottom. One at the battery compartment and the four remaining ones on the opposite side – leave the two at the tripod mount where they are for now. You can then remove the bottom plate. If you need you can unscrew the tripod mount to move it to the new bottom plate.
Since your post has been here for a while this might not be of interest to you anymore, but maybe it is helpful for somebody else in the future ;)
Cheers
Chris
这个答案有帮助吗?
得分 1
添加一条评论
Hello Chris, thanks for you answer. I did found someone who made the replacement but still I am sure that one more screw must be removed, the one on the side of the camera (the one with the focus selection lever. Please verify it, so people do not wonder about it, if they have to do it.
Cheers
Neven
这个答案有帮助吗?
得分 0
2条评论:
My apologies, I suppose you are right, Neven. I will remove the bottom plate in the evening to verify. Maybe I take some pictures and post them here.
由完成的
Hi Chris,
Have you had a chance to verify it?
Thanks,
M.
由完成的
添加一条评论
How do we buy a replacement base plate?
这个答案有帮助吗?
得分 0
1条评论:
I am selling mine. It has slight marks on it (that is why replaced mine.)
由完成的
添加一条评论
添加你的答案
Neven Miškulin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 46
总计 1,251
