跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
Service Battery Warning after subject to cold temperatures
Hi all,
I have a service battery message on my 2015 MacBook 12’ after I had left it in the kitchen yesterday when the temperature in the UK was -1 during the night! I specifically remember turning it off at 70% and putting it in its case. The normal working battery health for it is around 80% but when I woke up it was dead, I plugged it in and it said it was on 0%, and checking the battery health showed it was at 21%! I took it into the living room and put it next to the heater. After 10 mins I went and the battery health was back up to normal but there is still the service battery message, I reset the SMC multiple times but to no avail, and the message is still there. I am on the latest version of Mojave and have attached screenshots of my battery health, etc
Any help is greatly appreciated on how to remove the message
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You very may well need a battery - they do not like to be in freezing environments like that, so it wasn’t very good for it. I’m going to tell you how to try and fix it, but be prepared for the worst.
What you may be able to do to potentially recover it is to try recalibrating it - sometimes it works to save these batteries, other times it does not. Refer to this guide for some general instructions, but keep in mind it isn’t possible to drain the Mac batteries to 0% and go from 0->100% like with most PCs (with or without a workaround).
这个答案有帮助吗?
得分 0
1条评论:
Thanks for replying Nick,
I'd seen this on a couple of sites but don't have the patience, however, I will give it a go. From what I understand, do I need to charge fully to 100% and use plugged in for two hours and drain the battery continuously until 0% where I would leave it dead for 5 hours? After this, I charge it, and would the error possibly be gone. I was on live chat to apple and they said that my battery cycles are low for its age so it doesn't need replacing
Thanks
完成的
添加一条评论
添加你的答案
Isa Cheema 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 770
