Where can I buy replacement screen
who sells replacement parts?
Hi @cyberrescuers,
Here’s the maintenance and service guide for the laptop.
Go to p.13 Item #4 or p.14 Item #1 to find the part numbers for the LCD panel for the non touchscreen and the touchscreen model variants for the PC.
If you search online using only the part number appropriate to your particular model variant you will get results for suppliers.
The manual also details the necessary pre-requisite steps and then the procedure to remove / replace the panel.
Hopefully this is of some help
这个答案有帮助吗?
The issue with these Stream devices is cost :-(. Parts cost as much as a used one, or about as much as a new one on some of these.
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 55
2条评论
Hi @cyberrescuers ,
What is the full model number of the laptop?
由 jayeff 完成的
@jayeff I have a stream 13
由 klarenceray 完成的
