跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface Pro 2 是一个2013年发布的二合一平板笔记本解决方案。 Surface Pro 2 是 Surface Pro 的继任者,预装 Windows 8.1 并能升级到 Windows 10
Replacement Surface Pro 2 screen lacks camera bracket
The touch functionality has gone a bit wonky on my Surface Pro 2 (I get occasional “phantom touches” down the left side of the screen), so I’ve decided to roll the dice on opening it back up and replacing the LCD assembly.
Looking at the replacement LCDs available (including the ones that iFixit used to sell), they all appear to be missing a plastic bracket that surrounds the space where the the front facing camera peers out of.
I wanted to ask if a) anyone had any idea of how to swap that piece between displays, or if they knew where to buy a replacement or b) what the effect of leaving it off might be. I suspect it might have something to do with the white camera light that comes on when you turn on the front facing camera.
Any help anyone could offer would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The bracket is held in place by a sticky material, probably some kind of double sided tape. You can jimmy it free, preserving the bracket, using a guitar pick and gentle pressure. The circular part of the bracket, which surrounds the camera hole has no adhesive, so you can easily slip the pick under there, and then move towards the sides where the adhesive is. Heating the bracket first (mildly, don't even get close to the temperature to melt the bracket) using a hairdresser / heatgun may allow you to preserve the original adhesive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
frizbon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 381
