A capacitor that says H1R5 fell and detached
A capacitor that says H1R5 fell and detached, as a result it does not give sound. Do you know what the exact model of this capacitor is? or the features to get a replacement.
Marcos Henriquez post some picture of the component with your QUESTION. The numbering that you listed as being on the component makes it sound more like a 1.5µH fixed inductor. We would need to see the component and where it was located on the circuit board.
As suspected what you have there is a 1.5µH fixed inductor. Those are readily available at places like Digikey, Mouser and many others.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 798
Hi,
Are you sure that it is a capacitor and not a resistor?
What is its component identification designation on the circuit board (if any) Cxxx or Rxxx or maybe something else?
由 jayeff 完成的
Hi,
If you remove the board and find out where the component belongs, hopefully there may be a designation on the board which will further identify or verify what is is, e.g. C = capacitor, R = resistor, L = Inductor, Q = transistor, T = transformer etc
The component appears to have tags on each side. Have you tried using an Ohmmeter to measure it? if it has continuity it may just have to be soldered back onto the board.
由 jayeff 完成的
