跳转到主内容
The most popular option to light large areas of buildings. They come in a variety of connection types and power ratings.
22 个问题 查看全部
Why 32 watt bulbs will not work?
I have 48” fluorescent fixtures in my kitchen and I assume they are identical recessed fixtures since they came with the house. I have 32 watt fluorescent bulbs in one fixture that work fine, but in the other fixture it will not work unless I install 40 watt bulbs. Is the ballast going bad???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@ifixit2021 both the 32W and 40W are of the same type i.e. (T8-T12 etc.)of fluorescent bulb?
完成的
No the 32 watt is the smaller 1" T8 and the 40 watt are the larger 1.5" T!2.
完成的
添加一条评论
1个答案
@ifixit2021 you may run into the issues where a T12 primarily run off a magnetic ballasts and T8 bulbs operate on electronic ballasts. Try another T12 and see if that works or change the ballasts to the T8 type.
这个答案有帮助吗?
得分 0
1条评论:
So I put T12 bulbs in both fixtures and they work. I guess because someone in the past may have replaced the ballast in one fixture T8 bulbs will not work. Unless if it's possible the ballast in one fixture will not accept less than 40 watt bulbs. The T8's are 32 watt
完成的
添加一条评论
添加你的答案
Chuck`` 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 2,662
