跳转到主内容
主板和 CPU 维修指南。
166 个问题 查看全部
Headphone jack replacement possible?
Hey guys, I have a motherboard that gas been running for 2+ years and my headphone jack snapped off and got lodged inside the rear audio output of my motherboard. My stupid self tried to drill out the jack but instead broke the port itself. Is there any way I can replace it? I have the necessary tools to do so. The jack is made by lotus if you were wondering. Thank you!
Edit: the motherboard is the Gigabyte GA-Z68x-UD3H
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@zantheproplayz post some picture of the broken part as well as the underside of your board with your QUESTION. It is most likely possible but you may have difficulties finding a proper replacement. You could try and match a replacement by measuring your old one and then checking with Mouser, Digikey, Jameco etc. for a replacement. Let’s see how bad this looks. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
4条评论:
You can’t really see the damage in picture but it a mix of plastic shavings and metal
完成的
I am actually more interested in seeing the connectors location, shape etc as well as the underside to see if it is a through-the -hole connector etc.
完成的
Its a tht connection and the whole entire thing is a rectangle like shape
完成的
@zantheproplayz
Is there any information printed on the component itself that may help to identify it.
I know that it is a 6 x RCA type but finding a complete unit is proving difficult.
You may have to connect via the front panel audio headers - see p.29 Item #12 if you can't get the required part
完成的
添加一条评论
添加你的答案
Zander Castillon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 61
