跳转到主内容
加入维修社区 - 创建账户
27英寸显示屏,分辨率为 2560 x 1440 像素 Thunderbolt 与 MagSafe 线缆连接
Chemical smell... power supply?
Hello, I started noticing a strong chemical smell coming from the bottom left air-vents of the Thunderbolt Display, but no other signs. The brightness is fine, it powers the MacBook, and no strange behavior. I ordered a PSU replacement, did I make the right choice? Should I also replace the FAN? (but I’m finding only used fans…)
Update (02/18/2021)
@danj Thanks Dan, mine is different. Look at the photo, I marked what seems to originate the bad smell. Is still the component you mentioned before?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
22条评论:
Without opening it up to inspect things it could be anything!
由完成的
Hello Dan thanks, yes it could off course... but I didn't want to open it without first having something to swap, as I have fear for that delicate wires that need to be disconnected to separate the two monitor parts. I wanted to know if, based on experience, this smell could indicate a faulty PSU, as the fan itself shouldn't make burning smell (am I right?), and it pushes air through the PSU pub and then it gets out on the left air vent at the bottom
由完成的
I've replaced more logic boards than PS on these monitors. A fan would not be the first thing I would suspect.
由完成的
Thanks, so I need to open it and check every power rail I suppose? At this time not other sign of malfunctioning (unfortunately). I could keep in using it, but the only thing is I have fear the smell could be toxic.. what did you find on defective logic boards?
由完成的
Burnt caps mostly
由完成的
显示更多的17条评论
添加一条评论
1个答案
Here’s a marked up image of some of the of the major parts
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vanx 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 1,458
