跳转到主内容
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
Speed only works on highest setting on the dial
Hi my Kenwood mixer will only work at the fasted setting on the dial
Update (12/18/2020)
  • On the fastest setting on the dial
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
9条评论
Can't find an option to add a photo
完成的
@freddifrog here is the guide for it. 在已经存在的问题里加入图片 You'll have to edit your QUESTION and add those images to it.
完成的
Thanks. Just having a look.at it now
完成的
Apparently I need a part
完成的
I need a part BTA208-600B
完成的
显示更多的4条评论
添加一条评论
2个答案
已选择的解决方案
@freddifrog this is most likely caused by a failed spark suppression capacitor for the governor. IF it fails your mixer will only work at full speed. Check for it under the cover on the bottom of the motor. You’d be looking for a small, round, aluminum can looking part. Post some images of what you find so we can assist you further with that.
Here is Untitled the service manual to help you with your disassembly etc.
这个答案有帮助吗?
得分 1
2条评论:
there are two aluminum can looking parts but how do I know which one works and how can I replace it and where can I get the part?
完成的
There's sure to be a label on it. Post a photo here, we will help. Replace both, they're cheap. You can usually get them through an mail order company for electronics.
完成的
添加一条评论
I had the problem on kcc9060. I changed the dial element (so the triac) and i solved the problem.
这个答案有帮助吗?
得分 0
1条评论:
The problem returned its not the dial maybe the motore rotation sensor
完成的
添加一条评论
添加你的答案
P Greenwood 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 31
总计 1,062
