跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 个问题 查看全部
Black screen, ring, no image on the screen, burning smell
Hi, I am trying to fix my iMac which stopped working. I opened it, when I press Power button all 4 green lights turn on, and one of the parts starts burning:
https://youtu.be/QY-B5TLIU9E
Is it something that can be fixed?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
You have a short within the logic board! The sparks are around a Via which is a connection between different layers.
At this point you’ll need to find someone with deep skills to fix this or just replace the logic board iMac Intel 21.5" EMC 2544 Logic Board Replacement
这个答案有帮助吗?
得分 2
1条评论:
Thanks, I will probably do that.
完成的
添加一条评论
@earmand all of those connections and points are part of your backlight circuitry. The component right next to it is C9712.
Disconnect your LCD and check to see if that makes a difference. You also want to consider posting some really good pictures of your logic board with your question. Maybe we can find something obvious. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Efim Armand 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 164
