跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
176 个问题 查看全部
Need to know different chips one logic board
Bought this IMAC broken and am trying to fix it. It looks like a couple of chips are cracked and or broken off on the logic board. If anyone could tell me what exactly these things are and possible where I could find some new ones to solder on.
Thank you,
David
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
@dclnine - You'll need to find the board number so we can try to find the correct schematic and board view to figure out what you've damaged.
From what I see I suspect you have damaged inductors as part of the Ethernet port. Without looking them up I can't tell you the values.
完成的
I believe the board number is 820-00629-A. If thats not the right number please let me know and I can try to find a different one.
完成的
添加一条评论
2个答案
已选择的解决方案
Sorry I don’t have the needed drawings you’ll need to get it your self 21.5" iMac A1418, 820-00597-A BoardView, Schematic
这个答案有帮助吗?
得分 0
10条评论:
Got the schematic thanks for pointing me in the right direction. Im not really that great at reading these things but it says one of them is t4000 and im still trying to find the other one. If I sent you a copy of the schematic would you be able to help me decipher it? Also I can give you my email so we can communicate that way.
完成的
@dclnine - If you want post the two files I'll take a look.
Look at my info card for my email address
完成的
Sent an email your way.
完成的
@dclnine - check to see if it bounced, did you use the underscore?
完成的
I did use the underscore.
完成的
显示更多的5条评论
添加一条评论
最有帮助的答案
@dclnine you are correct. One is T4000 and the other one is T4025. Both of those parts are LC607-AP-AFT453220M-171-T001 pulse transformers made by TDK. Sorry datasheets etc. no easily found.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the reply. Any chance you know where I can find one of these logic boards for not a ridiculous price?
完成的
添加一条评论
添加你的答案
David Laird 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 382
