跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
How to upgrade graphics output
I have a church customer running a 2013 27” 3.2 GHz i5 with 16 GB of RAM and a GeForce GT 755m 1GB GPU. They need to upgrade the video output.
I see where the CPU is upgradable but cannot tell if the GPU is upgradable to the 2GB.
OWC showed no upgrades.
Is it or is there an external upgrade possible?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@mayer - Sorry didn’t see your post ;-{
None of the newer 2012 and up have MXM boards so no its not upgradable. The Video RAM I guess could be upgraded to 2 GB but that would require desoldering the BGA chips and having access to the needed replacements.
Frankly, I think thats pushing things a bit far. I would look at an external GPU unit, you who'll still need the GPU board (PCIe). Due to the limits of TB2 you’ll need to use the eGPU port fort the display output.
References:
这个答案有帮助吗?
得分 1
2条评论:
@danj thanks for the tips. Would you even recommend it or would a new Mac Mini be better? I have never even seen an external eGPU unit.
完成的
@mayer - If you are talking about the new M1 based Mac Mini that might be a good direction depending on what work flow is.
The reviewers appear to be gitty with glee on the performance they have measured. I'm thinking on finally upgrading my 27" 2011 to one maybe in the spring.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 530
