跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Will a Display replacement fix this?
Hello,
A while ago I fell longboarding with my phone in my pocket. At first there was a hairline crack that went up and down the screen. Over time it appeared the crack was spreading and it became a back blob.
If I take my otterbox case off I can see what is on the screen where the black blob is. In light I can see the whole screen, it just looks like the backlight isn't working where the black blob is.
The front glass is fine, the only damage is to the internal display.
My question is what do I need to fix this, I'm not sure if it's a backlight problem or if it's a cracked lcd screen. Would a Display Assembly kit fix this, it appears to be the easiest way to fix my problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Is this on the digitizer or display? If it's on the digitizer, you can replace this part as a single piece on the 3GS. It isn't like the 4 where you buy the whole thing.
iPhone 3GS Front Panel Assembly Replacement
If you broke your display then you need the LCD. You can buy the unit as a whole, or just the panel. I would buy the unit at this point, since it costs about as much as a LCD only anyway.
iPhone 3GS Display Assembly Replacement
iPhone 3GS Display Assembly图片
指南
难度:
中等
15 minutes
iPhone 3GS Front Panel Assembly图片
指南
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Scott White 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 368
