跳转到主内容
The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
41 个问题 查看全部
Xiaomi Mi A2 Lite Battery Issues
My Mi A2 lite’s display cracked so I was replacing the display. However, when I tried to check if the display was working, the phone no longer powers on. I must admit that when I tried to pry the battery out that I might have damaged it. I felt like I bent some of the edges of the battery but visually it looks fine.
When I plug the phone onto my PC, I get a power surge on usb port warning.
I’ve also tried reconnecting everything with the original, damaged screen and the phone still doesn’t work, so I’m guessing that the display is not the issue.
I’m wondering if I damaged the battery which is causing this issue or if it might be a problem with the motherboard.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
sdfjh32r  yes, this could easily be caused by a failed battery. Replace the battery first then re-evaluate. Let us know what you find.
这个答案有帮助吗?
得分 0
1条评论:
I figured out the issue, it was because the connector strip was installed backwards lol. Now I have to figure out why my new touchscreen isn't working, even on the cracked screen...
完成的
添加一条评论
添加你的答案
sdfjh32r 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 381
