跳转到主内容
A laptop by Lenovo that can function as a tablet.
45 个问题 查看全部
After open bottom cover a Motherboard part attached to magnet in cover
While doing a SSD swap, I removed the Bottom Cover, when preparting to assembly I notice a part of the motherboard attached to a magnet in the cover
See where the item is missing
You can see in this picture how the part should be (but is actually loose already)
and how the cover has a magnet there (I assume is for cover detection)
After this happened the Laptop is not powering on. Can we repair/re-attached the component? If a new motherboard is required, how can we avoid from happen again? the loose component is almost in direct contact with the magnet once installed the cover
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Alejandro Ontiveros  the component is a simple 1µH fixed inductor. I would not even doubt that you can resolder the one you have. As for preventing it, that will be a bit tougher. I’d try a few layers of aluminium foil over the inductor to prevent it from sticking to the magnet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alejandro Ontiveros 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 94
