跳转到主内容
加入维修社区 - 创建账户
Installing MAC X OS
I have Formatted the Original HDD of the MAC A1150 using the DiskUtility of another MAC so that the Formatting Type is compatible….
I have created a Bootable USB with El Capitan Using command Line by the following command.
sudo /Applications/Install\ OS\ X\ El\ Capitan.app/Contents/Resources/createinstallmedia --volume /Volumes/TOSHIBA--applicationpath /Applications/Install\ OS\ X\ El\ Capitan.app
The CLi successfully formatted the USB and installed the Installation media for El Capitan enabling the USB to be a Bootable Device… However, When I insert the USB into the MAC > Power up the Mac whilst holding Option And then selecting onto the Bootable Device I am getting presented with……..
A FOLDER WITH A QUESTION MARK INSIDE !! Any ideas to why or how I can resolve?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You’re trying to install OS X 10.11 “El Capitan”, but assuming you put the correct model in (15-Inch MacBook Pro from 2006), the latest version compatible with that model is Mac OS X 10.6 “Snow Leopard”. I could be mistaken, but I’m guessing the reason you’re seeing that symbol is because El Capitan isn’t compatible with that machine.
这个答案有帮助吗?
得分 1
添加一条评论
Mac A1150 can not install from external drive has to be internal drive/ dvd drive only!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fire Base 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 1,187
