跳转到主内容
加入维修社区 - 创建账户
iPad Air Wi-Fi + Cellular,型号 A1475。有深空灰或银色可选,提供 16/32/64/128 GB 配置。
PMIC Replaced - Missing voltages
I have an iPad Air (1st gen) which I have replaced the PMIC. The reason for that is because the iPad charges only when it was switched off.
I have lifted the following pads during removal of the PMIC:
  • B17
  • B16
  • B15
  • C16
Dont know If this is the cause of the problems below:
  • No backlight (filters are good)
  • Missing voltage on PP3V0_SPARE1
  • Missing voltage on PP3V0_S2R_SENSOR
  • Missing voltage on PP3V3_ACC
  • No Heat on the board, and I can see apple logo on screen without backlight looping.
Anyone can point me in the right direction or explaining those missing voltage lines could be a BIG help understanding the situation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Peter,
too high temp and flow you use for taking off a glue and a ic. It seems like cpu overheated. Have you stencil for reballing?
这个答案有帮助吗?
得分 0
6条评论:
Yes! I have used a brand new PMIC already reballed.
Also I have measured around all Caps with Multimeter Diod mode wich resulted NO short on the board.
由完成的
Or you suggest I should reball the CPU???
由完成的
this is dependent to board measurement. But it looks like. I would measure RAM and NAND beforehand but it looks like yes, I would do a CPU reballing.
由完成的
sometimes, problem is in technical's hand work. Are you sure IC is sitting down correctly?
由完成的
A smudged the corners and it seems ok....
由完成的
显示更多的1条评论
添加一条评论
添加你的答案
Peter Hupuczi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 916
