跳转到主内容
加入维修社区 - 创建账户
Pavilion Notebook 17 系列 17 英寸笔记本电脑的维修指南和支持。这些笔记本电脑的型号为 17-g000 – 17-g099。
USB slots not working
I went to plug in a USB phone charger and mistakenly had it upside down (It was dark) I didn’t force it in but pushed it in as normal thinking it was the right way up. As soon as I did that the laptop completely shut down. I took a look at the USB slot and seen one of the gold pins had been bent. I tried m best to bend it back into place after I shut it down. Once it was back on I tried the USB slot but again the laptop switched off. I then tried the other USB slots on the other side of the laptop and they don’t cause the laptop to switch off but they aren’t working at all. I looked online for help and already tried the method of removing the battery and turning laptop on then restarting again with the battery. Also tried going into devmgmt.msc and unticking the option that allows the computer to switch off USB to save power.
I can’t find any other solutions and was wondering if anyone on here had any? Any help is appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
What is the full model number of the laptop?
Did you remove or disconnect the main battery from the laptop before attempting to repair the USB port?
Even though the laptop was off there is still power available at various places on the motherboard. The laptop's Power button is not a power isolating button. It merely signals the BIOS as to the intentions of the user. Think of the laptop as being in an extremely low power state rather than being totally switched off, when it is off.
If not, then you may have damaged the USB power supply circuit or perhaps the USB controller.
Plug a USB device into the ports just to see if power is being supplied by the port even though the device is not being recognized e.g. a mobile phone - shows charging or a USB mouse - laser light turns on
You will have to open the laptop and inspect for any obvious damage. It may be easier if you open it up and then find the motherboard’s “board number” (printed on motherboard itself) and use that number to hopefully find the schematics for the motherboard as these will help you to know what board components need to be checked in case there is nothing visibly obvious.
这个答案有帮助吗?
得分 1
1条评论:
How to buy those slots - Die 3 poorten waar te kopen
由完成的 分享
添加一条评论
添加你的答案
wwestevo07 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 557
