跳转到主内容
Repair information for Sharp televisions.
105 个问题 查看全部
No picture but I have sound
Went to bed last night tv was fine, got up this morning tv picture is black but I have perfect sound?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Buen día, tengo el mismo problema. LCD MODEL 50BL2EA
完成的
添加一条评论
3个答案
最有帮助的答案
@sheffwife we need your TV's complete model number. You also should let us know what you have already checked (Tried all different Video input sources etc.) You also want to try to unplug the TV and unplug all accessories connected to it. Then hold the power button depressed for something like a minute or two. After that plug one video source, preferably local like game console, DVD/BR player etc. and see if you now get video. If not the check in a darkened room, shine a flashlight at an angle against the TV screen (TV must be on and you have to have sounds etc.). If you can make out shapes, silhouettes etc., then you know that this is a backlight issues. If not then there is the possibility that this is a main board, power board, T-con board or even the display panel. We would need to see your boards etc. to make any kind of further repair suggestion.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
2条评论:
Model LC-4OUG7252K
Tried to reset, but now sound gone as well!
Any further help/advice would be good?
Thanks
完成的
@Paul Casey How did you attempt to reset? What did you check before?
完成的
添加一条评论
Led light could be blown and shorting other led off or t-con board may be damaged in an LCD TV
这个答案有帮助吗?
得分 0
添加一条评论
the power light is on, the picture is dark
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pamelapreston24 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 38
过去 30 天: 139
总计 11,923
