跳转到主内容
加入维修社区 - 创建账户
iRobot 推出的 Roomba 980 扫地机器人。于 2015 年 9 月发布。
Keeps throwing a code 2 to empty trash
Keeps saying to empty trash but there is no trash in it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Error 2 on an iRobot Roomba 980 usually means that the rubber brushes are clogged and need to be cleaned. The most likely cause is hair stuck on the brushes, which is preventing them from spinning properly.
To fix the error, you can try these steps:
  1. Clear the brushes
  2. Pull the extractors out, clean any debris/hair on the ends, and pull the yellow end caps off
  3. Press the CLEAN button to restart
If the Side Brush is not spinning after cleaning, you may need a replacement Side Brush Module.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Strain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 385
