跳转到主内容
Media players with CD read capabilities
100 个问题 查看全部
Releasing a ribbon cable from the mother board
I have a Pioneer CD player with a bad optical pickup assembly. The ribbon connector attaching it to the mother board will not release. The connector has no visible tabs to press or lift and appears to be a solid block soldered to the mother board. How do you get the cable released?
Update (11/01/2020)
Pioneer PD-M500 CD Player
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@jbtjr we will have to see what kind of connector this is. There are plenty of them around and unless we can see your connector or at least a model number, we cannot answer this. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
I got it! The ribbon is just a friction fit into the connector. It was tight, so you have to pull straight up with a steady but very firm pull and it came out. Problem solved!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Todd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 168
