跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Faded corners in the display of MacBook Pro Mid 2012 13 inch
Hi Guys,
Hope you are all doing safe!
Jumping on to the top straight away, I am having a white border fade issue in my macbook pro mid 2012 13” inch.
This fade is surely due to hardware issue (not sure if the display is the issue or something else).
The edges of the display is faded while the 4 corners have the maximum faded area as shown below:
Is it worth to get a display replaced for the model? Or Can I use it as it is?
I am happy to use it in the current way, but little skeptical if this fade would keep on increasing day by day :(.
Do you guys have experienced this issue earlier?
Please put in you suggestions and thoughts here.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Avinash™ Kumar what you have here is a failing display. Yes it could “f this fade would keep on increasing day by day” but it can always buy you some time before you have to replace it. In the meantime I would suggest use it until you feel it is time to either replacing it and/or keep it connected to an external display.
MacBook Pro 13“Unibody 2012中期显示屏更换
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Avinash™ Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 419
