跳转到主内容
Repair and disassembly guides for electronic keyboards.
214 个问题 查看全部
Keyboard only works after unplugging it for about an hour
I have a YAMAHA P45B, digital piano. Up until recently, my keyboard has been acting up.
When I try to turn it on, the red power LED flickers non-stop and is completely unresponsive.
However, I leave it with the power adapter plugged out, after about an hour, its working again.
But when I turn it off and on after, the issue returns, LED flicker no sound.
I'm only able to turn it on normally if I leave it with the power adapter plugged out for about an hour.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
First name  sounds like something overheating on the power board. We really would need to see the boards. So, disassemble it and post some good pictures of your boards with your QUESTION. That way we can try to narrow it down. To work on your Keyboard, download the SM from here Page 60 and on will help you to check your boards.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
1条评论:
I ran the test program from the service manual, everything seems to have passed, and ran the test on the test points, all values seem to be fine. Also uploaded pictures of the circuit boards
完成的
添加一条评论
添加你的答案
First name 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 88
