跳转到主内容
加入维修社区 - 创建账户
华为2019年4月的旗舰机,搭载6.47寸FHD+OLED屏,屏下指纹,40MP主摄,加8MP远景镜头和全新的耳机扬声器技术,型号VOG_-L29和VOG-L09
Touch screen no longer working
The touch screen no longer works nor reads fingerprints. What part of the phone should i replace? No cracks on the screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Right side touch not working
完成的
Bottom half of The screen not accepting PIN etc
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @judynguyen ,
Just verifying that there isn’t a screen protector covering the screen as sometimes these can interfere with the correct operation of the touchscreen but more so with the fingerprint sensor which is located in the screen itself.
Try starting the phone in safe mode just in case it is a downloaded app that may be causing the problems.
If still no good try wiping the cache partition just in case it is corrupted cache data that is the cause of the problem
If it still fails then just because there are no visible cracks on the screen doesn’t mean that there hasn’t been any damage to the delicate internal connections in the display assembly itself.
As a DIY repair all you can do is to open the phone and check that the display assembly flex cable connection to the motherboard is secure and if it is, then to temporarily replace the display assembly to determine whether the problem is in the display or the systemboard.
Here’s the ifixit 华为 P30 Pro 显示屏和触控板更换 guide which should help you to do this.
Replacement display assemblies are available online. Just search for Huawei P30 Pro display assembly to get results for suppliers that suit you.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
JUDY N NGUYEN 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 40
总计 2,792
