Tv turns on but no sony logo then shuts off. Blinls red light 5 times
Sony KDL-70R550A
What can I change to fix the problem? I changed the power supply board but still did the same thing. Could it be any of the other 2?
@santanaj not sure why you would have changed the power supply board. The 5 blink error code can have quite a few different causes. Ranging from the T-con board to the panel and few things in between. Start off by removing the cables between the T-con board and the LCD panel. See what blink code you get. Then turn your TV off and connect the right cable only. Turn it on and see what happens. Do the same with the left cable. Always turn the power off before switching. Let us know what you find out. This can be a T-con board error but it can also be a Side driver issue on the panel.
这个答案有帮助吗?
Thank you.. I will let you know as soon as I try it. Thanks again!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 132
