Where is the egr valve located on 1998 mazda 626
where is the egr valve located on 1998 mazda 626
It's underneath the throttle body. Round in shape, has an electrical connector for the EGR lift sensor and a vacuum line is connected to it. Check the attached diagram. I would definitely clean it first and make sure that your vacuum lines do not have a leak before replacing it. No a common part that wears out. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 5,001
1条评论
Thank you for accepting my answer and good luck to you.
由 oldturkey03 完成的
