跳转到主内容
加入维修社区 - 创建账户
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 触控转盘
interface port on iPod
My friend leaves his ipod classic plugged into his stereo in his truck at all times. It has been bumped a few times and the cable no longer makes a good connection all the time. Is there a way to reinforce the port on the logic port so it will not fail?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the cable is loose at the bottom of the iPod, the dock connector, then there is really not a lot that you can do. The little spring pins may just have worn out. I would try a new cable and see if that makes better contact. The only way to fix the dock connector is by replacing the logic board. Not a terribly expensive or difficult undertaking.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matt Shirey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 520
