跳转到主内容
A repair page for the Kindle Fire HD 10 7th Generation Tablet/E-Reader by Amazon.
15 个问题 查看全部
Replacing ribbon flex connector
I am trying to replace a motherboard ribbon connector as circled in the image on a amazon fire 10 where the flex ribbon cable slides into that the previous owner messed up. Is there a way to determine the number of contacts and pitch of the plastic connector or an easy way to determine the exact replacement connector I need to buy? Don’t know if it helps at all but on the flex cable itself there is a number 1 written on one corner and number 51 written on the other corner which is also written beside the connector as you can see.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@ntec those numbers are the position of the pins. Number 1 on the connector has to correspond with number 1 on the cable. It is not useful to find a replacement. Since there are no schematics available you would really have to do some tough searches at places like mouser.com digikey.com for something like this to see if you can find a match.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 214
