跳转到主内容
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
Suddenly shows red in areas of dark black
I was watching TV this morning everything working fine, left it on and went about my day, and when I came back had this issue. In areas where there's supposed to be full black or close to it I'm getting a solid dark red. There is no gradient to the red color at all. This also persists throughout all inputs so it it the tv.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
Hi @akilogames,
It may be a problem with the tcon board. This regulates the colours dependent on the signals being received from the mainboard or worst case it is in the panel driver tab boards that the tcon board connects to.
The cabling is mainboard —-> tcon board —-> tab boards ——> panel.
There’s not much you can do if it is in the tab boards because their connections are bonded to the panel itself and are very fragile so you risk creating more problems trying to fix them.
Here’s a video that may help. It is not for your model as far as I know, but it shows in general terms the tcon board and the cabling etc
Replacement tcon boards are available online. Just search for Samsung LN46A530P1FXZA tcon board. Make sure that the replacement board has the same board number, Rev. No etc (printed on the board itself) as the original or verify with the seller that it is compatible with your exact model. Also try to source from a supplier that has a good returns policy that may minimize the cost to you if it is not the tcon board that is the problem.
这个答案有帮助吗?
得分 1
添加一条评论
@akilogames this is either a bad T-con board or a failed panel. I’d replace the T-con board to rule out the panel.
这个答案有帮助吗?
得分 0
添加一条评论
Honestly bestie I just knocked on the back a couple of times and it’s like it never happened
这个答案有帮助吗?
得分 0
添加一条评论
Take the cord out, blow on it, unplug ya cords and everything should be okay
这个答案有帮助吗?
得分 0
添加一条评论
We had this problem yesterday. Woke up to a TV (that's only 3 years old) that had sound, but screen was black and red. We thought about calling a repairman or even buying a new TV. Someone recommended that we reset it (I guess every TV has a reset button), so we did ..... And it worked! TV working just fine again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 176
总计 12,105
